I recently made a thread saying that my car was getting close to overheating, and my mechanic has got it to run better but not quite right. Apparently our cars fans are designed to kick in at 190 degrees, well mine was kicking in at 220 degrees. My mechanic did some research and replaced a sensor that tells the ecu when the engine is 190 degrees. He said that it is now better, but not as good as he would like it to be. What do you guys think the problem is???
My Car is running hot
Was the t-stat changed? How is the radiator? Still good? Not rotted out. He changed the temp switch in the t-stat housing but while your there why didn't you change the t-stat to oem specification of 180f/82c. Change the thermostat.I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!
Originally posted by daheavyking View PostWas the t-stat changed? How is the radiator? Still good? Not rotted out. He changed the temp switch in the t-stat housing but while your there why didn't you change the t-stat to oem specification of 180f/82c. Change the thermostat.
