Hey guys, I have a BIG problem, as some of u may know I've been waiting on my crank which I just got back, but when I went to pick it up the guy that worked on it told me that my engine had bad lubrication because the journals were very marked. I removed my oil pump and measured theclearance and all were within spec, almost perfect. So my concern is, is there anything else other than the oil pump that can cause bad lubrication?
Just to let u guys know, while I was waiting on the crank I took advantage and clean every passage I was able to see and replaced all the gaskets and seals, What else should I do to make sure I I dont have this problem again? I am a maintance freak so now that this car is in my hands it will be getting all its regular maintanance intervals.
Please let me know what should I do...THANKS
