LED conversion and Odometer issue...
    I recently swapped all of my vehicles bulbs with LEDs. (Cluster included) After getting everything hooked back up, my odometer is no longer working. I've done LED swaps on multiple vehicles prior to this and never had such a problem. Any ideas?
    I searched the forums for unresponsive odometers and read a few posts concerning the VSS. Could this be the issue and me opening the cluster is just a coincidence?
    I have noticed on two separate occasions the speedometer needle bounce around or even drop to zero briefly at highway speeds. However, the speedometer has been working fine lately... Could it still be the VSS when the speedometer is operational?
    The sporadic needle issue could be a failing VSS. Perhaps now it finally went out. If you have another cluster, I'd swap that in and see if that solves the problem, if not, I'd look into getting a new speed sensor. There are ways to test your speed sensor, you have to jack your car up and spin the tire while probing the wiring and check the numbers, I don't remember what the parameters are, off the top of my head. But, they are in the Hayne's manual.
      You probably forgot to plug the motor for the odometer back into the clusters motherboard. I did the same thing once.
        Actually I did... I opened it back up yesterday and plugged it in thinking that would solve it, but still nothing.
          I can attest that a speedometer needle randomly dropping is due to your vss.
          This was the case in my brothers CD Accord. He used it till it actually made his d4 light blink
          I believe your modification to the instrument cluster has not caused this problem.
          Rides:
          Accord
          92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
          96-AUDM-2.2 VTiS- Heather Mist
          CR-X
          88-JDM-Si- Black
          CR-X Del Sol
          92-JDM-SiR "Transtop" Motegi Edition - Silver
          95-JDM-SiR "Transtop" Daytona Edition - Silver
          92-JDM-SiR "Transtop" - Black
          Prelude
          91-JDM-Si-4ws "Si States" - Phoenix Red
          91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
          91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
          91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
