ok so i want to hook up my windows to my aux out put on my alarm.i have 4 5pin realys and my alarm aux puts out a ground when activated.i tryed to hook them up but i dont know what wires to hook the posative relay up to.or is it a negative.well my question is has anyone done this and how in a step by step or a good diagram.
power window up and down with alarm?
Well I dont know how you'd go about doing that with just relays.. But there's something called a DEI 530T.
The DEI 530T window module allows you to control 2 different windows in both directions. Specifically, when the unit is installed with an aftermarket alarm, the windows will roll up when the alarm is armed. Then with the remote, you can either crack the windows or roll them all the way down.
Look it up on Ebay.. It's about 50 dollars including shipping.
The module itself is pretty simple to install(especially if you've installed your own alarm) but the hard part is going to be getting your wires from the inside of your door to the inside of the car. Some people have recommended taking the fender off and going through the factory grommet.. And others have recommended drilling a hole through the door and the kick panel.
Another thing you need to make sure of is that your windows are in good condition as far as how they roll up and down. If you have a lot of problems getting your windows up/down.. Then this module is not recommended because your windows may only get rolled up half way or down.. Which could create problems for you and compromise the security of your vehicle.
The module comes with pretty detailed instructions as to how to hook up each one of it's wires. And you can look here http://www.the12volt.com/installbay/...tail/1032.html for the details as to which wires work for the windows.
