Hope you guys can help me on this issue, I'm working on the front suspension bushings on my 91 accord ex sedan, installing the energy suspension bushings, but I'm stuck on the radius rods right now, for some odd reason 1 of the bolts lines up with the LCA, but the second won't...any ideas on why this is going on? Everything else lines up with the exception of the radius rods...any help would be appreciated....
91 accord radius rod issues....need some help please....
they line up.Originally posted by Pacific_CB7 View PostHope you guys can help me on this issue, I'm working on the front suspension bushings on my 91 accord ex sedan, installing the energy suspension bushings, but I'm stuck on the radius rods right now, for some odd reason 1 of the bolts lines up with the LCA, but the second won't...any ideas on why this is going on? Everything else lines up with the exception of the radius rods...any help would be appreciated....
it just doenst seem like it until you get the proper geometery going on.
always had trouble with that on my buddies CRX.
toss a jack under the LCA and lift until they align.
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
Radius rods still an issue....
Just tried working on the radius rods today since I had it free, but picked up the LCA to try and align the second bolt hole and still having issues with the rods...they are the same ones off the accord but with ES bushings...could it have something to do that since the engine is out I removed the front cross-member to clean it off, would have thrown off the spacing of the rods? Appreciate the help....
I took the front suspension off my 90dx a couple times with the engine in and out, and i can tell u its a pain to align the radius rod with the l.c.a, when I did my bushings I bolted the radius arm to the l.c.a before I secured the l.c.a to the cross memberOriginally posted by Pacific_CB7 View PostJust tried working on the radius rods today since I had it free, but picked up the LCA to try and align the second bolt hole and still having issues with the rods...they are the same ones off the accord but with ES bushings...could it have something to do that since the engine is out I removed the front cross-member to clean it off, would have thrown off the spacing of the rods? Appreciate the help....
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Yeah I know it's gonna be tough now, hehe....what if I bolted up the LCA's, bolted the radius rod to the LCA's , and removed the front crossmember and aligned the the rods with the crossmember off and bolted up the the crossmember with them in? Would that be something that would work? Cause the frame is straight just when I unbolted everything one bolt won't line up of the 2 bolts that go into the LCA's....
I have done it like this and it DOES work but then you have to align the cross member to the chasis which is hard to do with the radius rod hooked up.Make sure you use a Jack to push the cross member flush with the chasis then try and tighten the cross member boltsOriginally posted by Pacific_CB7 View PostYeah I know it's gonna be tough now, hehe....what if I bolted up the LCA's, bolted the radius rod to the LCA's , and removed the front crossmember and aligned the the rods with the crossmember off and bolted up the the crossmember with them in? Would that be something that would work? Cause the frame is straight just when I unbolted everything one bolt won't line up of the 2 bolts that go into the LCA's....
ended up finding there was some damage to the driver side portion of the front crossmember, i have a parts car so gonna take the cross member off that one and replace it when i pull the F22B1 out of that one...now gotta get some rear disc brakes for sure...i will keep you guys posted on the progress...thanks a lot again...
might as well get a 92-93ex rear cm and sway bar if your gettin rear discOriginally posted by Pacific_CB7 View Postended up finding there was some damage to the driver side portion of the front crossmember, i have a parts car so gonna take the cross member off that one and replace it when i pull the F22B1 out of that one...now gotta get some rear disc brakes for sure...i will keep you guys posted on the progress...thanks a lot again...
