how can i check/test it out?
how to check if my ecu is fried?
Originally posted by 809king View Posthow can i check/test it out?
The best way to tell is to remove it, unscrew the casing and check for burnt out capacitors and resistors.My pictures/photos will return soon...
And I agree with Joshy, pulling it out and cracking it open is probably the best method.Fix your Computer!
Originally posted by MikeWD, I'm a fanciful motherfucker. My ish is clean, quick, plush, mature and sophisticated.
ಠ_ರೃ
Originally posted by 809king View PostDoesnt want to start up at all
What else is going on? It's summertime, so you might want to check the main relay.My pictures/photos will return soon...
Originally posted by 809king View PostDoesnt want to start up at allFix your Computer!
ಠ_ರೃ
Originally posted by TypeG View Posttake your distributor cap off and have someone try and start the car. this will tell you if the timing belt has snapped or if the cam has broken. later.
i have no idea why it doesn't want to turn on.. i had it running then turned it off to connect the alternator, power steering and air compressor, then i tried to start it again and nothing. next day i took the alternator, power steering and air compressor off and it still doesn't want to startLast edited by 809king; 07-14-2010, 07:12 PM.
Originally posted by 809king View Posttiming belt is good so is the cam i triple checked
Slowly walk though electrical parts you've disconected and recheck them.Last edited by Masamune; 07-15-2010, 11:00 AM.Fix your Computer!
ಠ_ರೃ
