Brake Squeaking ????
    ok so my left tire squeak a lot how to fix this i been reading around u need to get ur brake pads replaced re grease the screw or something in ur calipers .. the brake will squeak when im driving slow but when i go fast or brake it will stop ... how easy is fix this can i do with with lil experience i got ? how hard is it from 1-10 ?
    well do you have disc all the way around ???
    i think brakes can be easy depends on the car
    but i would say disc r a 4 out of ten
    drums can be a 6 out of ten haha
    then again i have done alot of brakes so it must seem easy to me
      no its a 1990 lx so yeah only 2 disc and its the left front tire that is making the sound
        Is it your tire that is squeaking, or your brakes? They are two completely different parts.
        I assume it's the brakes. Brake pads are easy. You just need a ratchet to get to them, and a large C clamp to compress the caliper. Look up "disc brake replacement" on Google, or search for a video on youtube. You'll find lots of information.
          is the brakes i say tire because is coming from there and there for the vis thing that really gonna help i hope is the brakes
            Is the brakes are squeaking, it is not coming from your tire. The the tire is that big black rubber thing surrounding the wheel. The wheel is the metal thing bolted to the hub. The brakes consist of the rotor, also bolted to the hub, and the brake pads, pressed to the rotor by the caliper. If something is squeaking, it is most likely the wear indicators on your brake pads, as they are designed to squeak when your pads get low. Ignore this, and you will end up with the metal backing plates of the pads digging into your rotors (not something you want). You will need to get your rotors resurfaced when you replace your pads, or you will glaze them, and your brakes will not work correctly.
              dont make things difficult for your self, change your brake pads, and move on b4 its too late and u need new rotors....
                Yup, just change the pads. Get some Hawks (HPS) Their great and not too expensive.
                  i don't know about where you live but here i won't bother resurfacing the rotors because they are only $23 a peice and a resurface is $25 and new rotors are better than resurfaced
                  92 Accord EX - SOLD
                  PSN: REDxMAN-_-
                  MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
