Question regarding my EGR valve
    If my EGR does not work or is unplugged could this cause my car to stutter and about shut off after being driven until normal operating temperatures and shut off. Than restarted to drive again?
    Example:
    I decide to go to the grocery store for some milk. I drive the 5-6 miles to the grocery store shut the car off. Go in the store for about 5 minutes for the milk. Come back out and turn my car on and it stutter and idles real low like its going to shut off for about 2 minutes maybe less. sometimes more depends on the distance driven. But than after that period of time the car will idle and drive like normal.
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    maybe it is stuck open however it is usually consistent.
      But what if it is unplugged. Could that cause the idling?
        yea, if it was still stuck open, then egr would be leaking exhaust into your intake.
          hmm.. well i plugged it back in and it still continues to do it
            okay.
              it could just be stuck open, try blocking off the egr valve passages with a piece of cardboard or a cut up soda can. if you block that up and the problem persists, then you know its not the egr causing it. by blocking it off physically you shouldn't throw a cel.
                when you gas, does it struggle to get up or does it still drive like normal and just idles low?
                  hmm
                  im having similar issues ,but jus got the car so im not sure it drives normally ,jus has cel on throws a 12 code ,if i star it from cold no cell i put it into d4 and go it comes on ,should i buy a new egr and replace it or used one low miles ,nj still has emissions testing or i would block it off ,any awnsers
                    i throw no codes at all and it drives completely normal no bogging or nothing just when i start it up after its warmed to temperature
