striped VC bolt
    striped VC bolt
    Ok guys the VC gasket on my CB needs replaced but apparently one of my bolts is stripped... any suggestions?
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    Try heating it up if you can and then put some vice grips on it and try your best. Sorry to hear about that! I'm pulling a transmission from a cd and the axle nut was stripped.
      is the screw stripped or the hole it threads into?
      the screw is much harder than the aluminum it threads into.
      so chances are the threads in that hole need to be cleaned up or heli-coiled.
        Im not sure the nut just turns up top....
          ohhh... its stripped so that you cant remove it. gotcha.
          try and wedge a flatblade screwdriver btween the head of the screw and the VC. pry the screw upward while unscrewing. you might just grab enough thread to unscrew it.
          aside from that. you may have to be-head the screw and extract it with the VC off.
            true... I didnt even think about just cutting the nut off....
              i was just going to say i was in autozone today and i saw a nut cutting tool. was only a few bucks. idk what the quality is or how it works.
              Parts For Sale
              BIG Thanks to HondaFan81 for all your help!!
                Nutsplitter should work, or Hartman's suggestion of prying the nut upwards first. Try the prying method first. Then if that works you can rethread the stud using a regular die from the hardware store or a rethreading die (if you can find one) if the threads aren't completely missing. Otherwise you'll need to get a new stud at the JY or new.
