Doing an auto-manual conversion on a 93 Accord EX. Although the 93 EX has ABS, would i be able to use the 90 EX master cylinder? Last question, would i have to rewire anything at all for the manual trans or is it just plug and play?
Master Cylinder
the brakes and the clutch are two separate systems on the car. having abs brakes does not require any different kind of clutch master cylinder. all 90-97 clutch master cylinders are the same and interchangeable.
i believe there are a few less connections with a manual trans. cant remember what though. should plug up no issues. just make sure you have all the parts to do the swap properly.
are you wiring up the neutral safety switch or are you going to rig it to where the car thinks it's in park all the time?
Any questions regarding performance, maintenance, or repair belong here. If you want to go fast, or just change a flat... this is the place to ask!
I rigged it like in that post. works fine so long as you remember to not leave the car in gear.
Thanks..i didnt know about this. ill have my brother help me on this part.Originally posted by Leung View Postare you wiring up the neutral safety switch or are you going to rig it to where the car thinks it's in park all the time?
