Trouble starting
    Trouble starting
    Here's the deal. My car either starts up immediately or it's a major PITA to get going. Monday It'd start, but then stall out. I turned the key on/off 10-15 times and it'd do the same thing. I pulled the ECU fuse for 15 sec or so and then it started.
    Today, same thing. Pulled the fuse but this time it didn't make a difference. Eventually I got it started but... wtf?!
    Any ideas? Spark plugs? Wires? Distributor?
    My Car
    FREE Web hosting solutions
    i had the same issue a while back, and it was the dizzy.
    but i had ruled it out completley because i had just changed the igniter and figured it was fine. so after a few days of fighting it, i threw on a spare dizzy that i had laying around. and it started right up.
    so just do what you can to rule things out. like change dizzy, make sure its getting fuel, pull a junkyard main relay and throw it in, borrow a freinds ecu. easy stuff.
      Easy stuff as long as you have friends with CB7's :P
      My Car
        i would replace all the easy things that could be the culprit right off the bat
        1. plugs
        2.wires
        3.dizzy
        if thats not the problem its most likely a fuel issue
        You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
        Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
          Sounds good. I can get plugs and wires easy enough but does anyone have a working dizzy for sale?
          My Car
            What's the first thing I should try? I'm thinking coil or distributor but... yeah they're pricy.
            My Car
              before you start buying parts and throwing your money around recklessly, go buy a multimeter and check to see if the component is bad before replacing it. i bought a multimeter for $5. any part you replace inside the distributor will cost 10x that easily. just a fyi if you change the whole distributor you will have to reset your timing, which can be difficult for some people.
              Parts For Sale
              BIG Thanks to HondaFan81 for all your help!!
