Not starting
    Not starting
    I just got back from vacation on Saturday. Tried to start my car Sunday and it wouldn't start. Tried jumping it and still wouldn't start. Then about 3 hours later I gave it another shot and it started. Drove it Monday and Tuesday no problems except maybe once it took an extra second for it to start. Drove it today to work and then couldn't get it to start after work. I recently replaced the plugs and distributor. It cant be the battery I don't think because my cd player and all that turns on when I try to start it. It just continuously cranks and doesn't turn over. Could it possibly be the main ignition relay? Any suggestions would be great. Thanks.
    it has to be the fuel main relay showing signs that u need a new one.....once you turn the key try to keep things quiet and try to hear the gas flowing through the injectors...another thing.....check if the injectors have ground....last time after i removed my intake manifold for a head gasket change fuel wasnt getting to the injectors untill i applied ground power then woah fuel squirted out!!!...lol...the fuel main relay is right under the drivers dash a lil above the fuse box under there you have to remove a couple modules to getto it....i didnt...
    .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
      last night I went down to try and get my car again and it started right up like it did previously. Is there a good place online to get a main relay or just any carparts is good?
        go to ur local junk yards.....but like i always say those main relays are small enough to fit in your pocket.....im just saying i didn't wanna spend 35 or 50 bucks for something that might not work....
          in extreme heat and cold ,the sauter can break or just warp, you can fix if you have a sautering gun bro... but dang turboaccord has a good idea.lol.good luck and i wish you the best..
