ok so today i spent like 7 hours working on my car. i changed the EGR plugs and since i had the fuel rail off i changed all the o-rings on the fuel injectors. also i changed my vss because it was broken. so after putting everything back together the car did not start at first b/c no fuel in the fuel rail. so on the 2nd or 3rd try it started. it is idling very low though. and when i drove it around the block the car jerked pretty hard a couple times between 2k and
3k rpms. it did not do it just once either. at first i remembered i forgot to reconnect a vacuum line and the pcv valve. i stopped and did that but it did not seem to help. i also had a little trouble getting the fuel rail back on but i think i got it down tightly. also the odometer does not work. i thought the vss would have fixed that but it did not. when the car started to jerk i would push in the clutch and it would stop. it did it mostly in 2nd gear but i dont think i got past 3rd gear. i drove it only a mile or so. any ideas?
