rubbing tires really bad!!!!!!!
    so i lowered my accord on megan sleves stock struts going to change struts soon but whn my car bottoms out or whn i turn the wheel my tires rub and get ate up by tha lip on the inside for the inner fender platic pice i was wondering is there anythng i can do about that i ruined a brand new set of tires my rims r stock ones tire size is p205/65/r15 or could it jus b my tire size pls help
    STANCE|WORKS
    Tires are too fat.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      thnks for tht jus needed a second oppion wht tire size would u recomend or does anybody else hve any suggestons
      STANCE|WORKS
        i had the same problem when i had my asa 240sx rims on her.. they were 205/55/r16 and when i bottom out it cut the SHIT out of my real tires.. i also ruined a brand new set of winters.. id recoment changing ur tires to 195's on the stock rim.. worst case just trim the lip on the inside..
        #3MR 91 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=186456
        #2MR 90 sedan: http://www.cb7tuner.com/vbb/showthre...51#post2867651
        #1MR 93 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=176343
          take the plastic lining out completely. doesnt hurt anything.
          and for for smaller tires. like 45 series.
          :Back In Business...
            get a fender roller and roll the fender to get rid of that lip. and get lower profile tires. that will deff fix the problem. also replace those struts quickly thats some of the reason its bottoming out so much and cutting your tires
            You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
            Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
              well thnks for all the help guys i guess im going to go and find a smaller tire today and the plastic linning on the driver side is out tht is tha side tht does it the worst passenger is still in but not as bad but i am just going to get a smaller tire cuz im half way on the coilover and i wanna go lower
              STANCE|WORKS
                You can use a wooden baseball bat to roll the inner fender lip up. Sounds ghetto but I know auto-crossers sometimes to it to squeeze a bit more width in there.
                  thought about tha bat but can i do the sam wit a fender roller or jus grind or cut tha lip down but imma defently get a smaller tire
                  STANCE|WORKS
                    I Cant Even Really See The Wheel That Well, Get A Closer Pic.
                    EDIT- SAYS YOU HAVE 205 65 TIRE, I HAVE 205 60 STOCK HEIGHT, I WANNA GO LOW BUT NOT THAT LOW, IF I DO GO LOWER THAN WHAT I WANT TO, ILL RUB.
                      Originally posted by cb7_tillidie View Post
                      thnks For Tht Jus Needed A Second Oppion Wht Tire Size Would U Recomend Or Does Anybody Else Hve Any Suggestons
                      195/55/15
                        Yes, a fender roller is the legit way to do it.
                          tires are way too big like everyone said
                          i had the same problem with 60 series
                          go to 55 or below and it will be fine
                          if you keep it like that it will rub a hole into your engine bay trust me lol
                          -Tyler
                            DUDE! your from murfreesboro ME TOO!!
                            my celly 653-8497 hit me up we should meet up tonight
                            -Tyler
                              yea im from murfreesboro i seen u a couple times u hve one of the nicer accords in the boro
                              STANCE|WORKS
