I have a opportunity to buy a 2001 honda prelude automatic h22 engine and tranny only . I want to put it in my 1992 honda accord sedan. It is already an automatic. What will i have to get. I know i need ecu, mounts( will prelude mounts work?) engine wire harness (which one) and will my stock axles work?. Is there anything else i'm missing? aren't the preludes equipped with an immobilizer how do i bypass that?
automatic h22 from prelude
Prelude owner to the rescue! Basic things you will need are; engine, tranny, ecu, and wire harness. The mounts for the H22 should be the same as the F22, mainly because the 92-96 preludes had both engines in their cars. Now, the H22 in the base model 97-01 is NOT the same as the H22 in the SH model. Mounts may be the same, but the ECU and possibly the harness are not interchangeable, so make sure you know which H22 you are getting first because if its the SH model, good luck trying to install that into your CB7.Originally posted by b20yimmy View PostI have a opportunity to buy a 2001 honda prelude automatic h22 engine and tranny only . I want to put it in my 1992 honda accord sedan. It is already an automatic. What will i have to get. I know i need ecu, mounts( will prelude mounts work?) engine wire harness (which one) and will my stock axles work?. Is there anything else i'm missing? aren't the preludes equipped with an immobilizer how do i bypass that?
Now, if its the regular H22 from he base model, I'm pretty sure the alternator should swap over fine. I think the power steering pump mounts differently on the F22 than it does on the H22. I don't think the axles will fit, so you might either have to find an entire H22 prelude suspension setup, or just swap over your current tranny onto the H22, bolts right up.
You also have to find a way to wire up everything onto your F22 fusebox, or get yourself an H22 one.
Hope this helps.
