f22b 98 and up
    f22b 98 and up
    will this motor fit in my accord?i kno the 92-96 bolt right in but will the newer one be the same?need help asap got this thing on hold.
    my new turbo build
    its an OBD2 motor. our cars are OBD1.
    itll work, but its not just a drop in motor.
      so can i use my stock mounts like the f22b swap guide says.
      my new turbo build
        should be able to. i think all the differences are in sensors and wiring.
          awsome.ill just use the f22a harness and turn the motor to obd1.also what ecu can i use...p39 from an obd1?or can i use another?
          my new turbo build
            The obd2 iacv sensor is different than our obd1. You would have to use a rosko racing iacv adapter plate, or the iacv relocation kit. Unless you can disable that sensor through a chipped ecu, if your not running a/c
              or use my h23 intake manifold
              my new turbo build
                http://www.cb7tuner.com/vbb/showpost...20&postcount=6
                Stick to the f23 IM. F22bx = f23ax intake ports
                  When was there a 98+ F22B? What did it come in?
                  In 1998, Accords had the F23A, and the Prelude had the H22A only. At least in the US... the Prelude may have had other engines, but I don't think it had any F22B engines beyond 1996.
                    97-2000 accord 98-2001 prelude.its the same twin as the 92-95 motor just a diff intake manifold and harness.will a p14 work to run this?reson i ask is because the jdm dont have a egr and the ecu im getting is from japan so i want to use a usdm p14 and the h23im.will it work.
                    my new turbo build
                      Yeah, a P14 will work. Not perfectly, but at worst I think you'd only be overfueling. You won't do any real damage, at least for a short time.
                      To my knowledge, the F22B was only used from 92-96. I've never heard of any Prelude having anything other than the H22A for F20A after that.
                        i said the same thing to the guy and he told me thats whats its from.so should i use the f22a injecters cause they are a smaller cc then the h23?or will the injecter stay open longer?
                        my new turbo build
                          H23 and F22 injectors are the same.
                            o shows how much i kno..lol so what options do i have to get this thing to run right besides paying 200-250 for a obd1 p39 usdm?
                            my new turbo build
                              OBD1 injectors, P39, and an OBD1 distributor (if this thing really is OBD2... I'm still doubtful about that)
                              I think that's it.
