disc brakes
    disc brakes
    okay i was looking around and seen some kit that convert the front disc to the newer kind thats go on the hub not thew staock pressed on type
    is there a cheaper way of doing this ???
    http://www.tasauto.com/Product/Detai...3&h=175&d=1764
    If you could find spindles off something that already has the rotor over hub then you could use those. They bolt up but has to be from an accord, prelude, or cl. I can't remember which years have it. Do a search for rotor over hub and you should find some useful info.
    Sig removed due to excessive size.
      http://www.tasauto.com/Product/Detai...nq=0&p=1&sz=50
      you could also piece it together...
      aftermarket hubs = (i sold mine for 140?)
      wheel bearings = 70
      raybestos rotors = 40
      cheap brake pads = mine were free but about 40 bucks
      thats 290 bucks and will be cheaper if you find a set of used hubs. you WILL need new wheel bearings, the inner race will be on the old hub and you cant just push them back together, it's a sealed bearing.
        wheel bearings = 70
        What kind of aftermarket bearing/hub did you buy to make it work since the bearings are pressed in?
        I don't know why but to me, the rotor isn't really a big deal at all. You'll have to remove the caliper bracket in all cars to remove the rotor. After that, it's just the 4 bolts that hold the rotor on to the hub and the axle nut. Rent yourself a slide hammer and hub puller and you're god to go. Did I miss something?
          man you guys do it the hard way , all you have to do is remove the caliper bracket, remove the axle nut tap the at the tip with a brass hamer so its loose in the splines, then loosen the four bolts that holds the bearing assy to the nuckle .i lossen the bolts out half way and tap onthe bolt heads with my brass hammer evenly and the hub and rotor come out complete . easy as pie...
