D4 light
    D4 light
    okay so i have a gauge cluster out of a wagon if that matters but the drive 4 light does not light up even after replaceing the light ????
    whys this
    You replaced the bulb? Make sure the wiring is good... otherwise, the cluster might be shot.
    What year is your car? What year is the cluster? That may matter, due to the Sport feature in the 90-91 years. In 90-91, transmission error codes are flashed through the S light. In 92-93, they're flashed through the D4 light.
      i cant recall the year thats that the cluster came out of
      it has a s on the right side of the display for the doors
      is there a wire i can swap around to make it work and mine is the 92 accord ex
        I'm not sure exactly, but if you have an S on the cluster, it's a 90-91 (if it's a wagon cluster, it's a 91)
        You MIGHT be able to rewire... but I'd say you'd be better off getting a cluster from a 92-93 if you want everything to work properly.
          kk
          thanks for the help
