car has electricity, but no crank..
    i can turn the car on and everything turns on just fine, the only problem is when i try to crank it nothing happens.. not even a click
    i'm assuming its the starter?
    could be or a batter connection not completely grounded
      Check all ur ground. And give it a try
        check available voltage at the starter.
          i'm having the same issue. My buddy [who i bought my second CB from] had the same issue on his 89 Yota. in his case, it was a bad clutch switch. i think that's what's wrong with mine as well. it's a cheap fix that's worth a shot.
