code 9 need help asap
    had code 8 and replaced the dizzy..now the car starts but I get a code 9
    how do I fix that..also my oil light is blinking
    Rush
    Originally posted by Darkcloud
    Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
    Originally posted by bmxicansd
    so you got a boombox, sunglasses and rosettta stone?
    That's messed up. The sensor for code 9 is inside the distributer, and if you're replace it (with new?) then it would be hard to say. Did you reset the ECU?
      the battery was off the whole ime..it started when I turned on the car..did I put the dizzy on wrong?
      the car was placed at TDC but IDk how to set the dizzy to tdc..so i might have messed that up..also is the car driveable like this?
      I gota take the car home and my house is 1 mile away
      Rush
        If this is an aftermarket dizzy, there could be an issue with the sensor. I've heard that aftermarkets have problems in this area. Are you sure it's not a TCU code?
        Since your oil light is blinking, I wonder if your ECU is flaking out. But I'm not sure what the oil sensor circuit is (if it goes directly to dummy light or to ECU), so it's hard to say.
        What year is your car? Auto or stick tranny?
        ***EDIT***
        Also, did you set the timing properly?
          I have a 93 accord, auto, timing was set to TDC on cylinder 1 and theres was only one way that the dizzy would work so I guess its on right..also the oil light stopped blinking now i only have code 9...the only thing that I dont know is are my cables on right..how do you set that up??
          when I put my cables onto the new dizzy cap I put them on the same way they were on my old cap..I turned the dizzy and the rotor part that has the metal end was pointing towards cilinder 4 i think..it would either be on cylinder 4 or 1..i tried putting it to 1 and it cranked but didnt start...flipped it around and starts but feels weird..
          its a used OEM dizzy that was in a running car...
          on a side note things that ive changed so far in the last 2 days: battery(new), starter(new), NGK plugs(new),and the used OEM dizzy..
          Rush
            By cables do you mean spark plug wires? I snapped a pic from my 92, but I think we should both have external coils. Sorry so dirty, I just got the car and haven't cleaned it up yet.
