Motor help
    Motor help
    how do i know my motor came with this without me having to take it apart?
    .webcam cam shaft
    .cp pistons STD 11.6:1
    .cp rods
    thanks
    Receipts.
    Otherwise, you only have the owner's word if you can't visually inspect the parts. Even then, you'd have to know what you're looking at.
      Receipts.
      yea i guess, but wouldn't I tell by the way it drives...like how it picks up speed.
      thanks anyways.
        Possibly... depending on the compression of the pistons, and how extreme the cam is. Of course, if it has high compression and a crazy cam, it's not going to like a stock ECU very much.
        Also, you may be able to tell that there is SOMETHING done to it... but you're not going to be able to verify the brands by the way it drives, obviously.
        Your only options to be certain are to see the parts, or see proof that they're in there.
          you can drill a hole in the side of the block and put a little camera in there.
          compression test should indicate compression with higher comp pistons.
          you should notice lower intake manifold vacuum with a more aggressive cam.
