best K series set up
    i was thinking what would be the best K series set up and with wat transmission for drag use. i have plans on building a k series whats your opinion? and why?
    I think for the money it takes for the swap, you could build a faster more powerfull single cam.
      06+ si ( lsd ) , rsx type S 05 06 ( non lsd ) but kaaz make a lsd, jdm itr, or custom geared dog box tranny.
      MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
      CHAMPCOUPE IS BACK !!!!
        The Hasport kit is made to swap in the Accord K24 engine. If you want any other, you're going to need to modify the kit, or fab your own kit.
        The cost of simply getting the engine in is going to exceed $5000, unless you have some considerable hookups. Then you can spend twice that much easily on a build.
        The gearing of the transmission is best determined by your engine's powerband. You'll want gears that take advantage of it. Until you know what the engine is going to do, you really can't say exactly what transmission is best.
        This is going to end up being a very expensive project. Prepare yourself. It's going to take a lot more research and preparation than simply posting "what do you guys think" on a forum! You need to determine your own needs and goals for this build, budget accordingly, and plan all your parts to work together.
          If you have money to blow... k24/k20 frank ftw! http://www.8thcivic.com/forums/engin...eeds-done.html
          2013 Ice Cream Cruise!
          VIDEO: 2012 Ice Cream Cruise
          VIDEO: 2012 Ice Cream Cruise part 2
          The single largest cruise in the Midwest!
          August 3 ~ Omaha, NE
          By 1320 Video
          Member's Ride Thread
              ive done a lot of research in the past and know enough to build my own motor and do all the work my self aside from tuning. i was jus wondering what ur guys opinion on it. well im pretty determined to stuff a k series in my cb7 because its only ben done by a few people.
              i have also seen some bad as single cams and they can take a beating but they have to spend a grand or so getting it to come close to what a k set up would put out stock yes i know the power to weight ratio is goin to be a factor bt a built k set up would look super mean and put down a ton of tq as well as horsepower yes its going to cost a lot of money but to me its worth it.
                go for it! it would be sick and is still a very original thing to do. Especially here in the midwest!
                By 1320 Video
