So yeah, I slam on the brake the other day to avoid hitting a deer and now my rotor are wrap. Every time the pedal is touch I can feel the steering wheel shake.
Question: Can slot & drill rotor be resurface? have anyone try this before I start?
Originally posted by wed3k View Postyou tell me? i do brembo's to porsche's on the brake lathe. dont let anyone else tell you, you cant do them. however, due to the center on our rotor design, i had to use the flywheel grinder.
upgrade to at least the prelude/vigor/wagon brakes in front, our 10.2" rotors are way too tiny for a 3000lb car IMO.
Originally posted by OCEAN View PostSo yeah, I slam on the brake the other day to avoid hitting a deer and now my rotor are wrap. Every time the pedal is touch I can feel the steering wheel shake.
Reason why I say that is if it warped due to an emergency manouvre who's to say they won't again another similar incident happens? It should make you think how good the materials used on the rotors really are.
I have slammed my brakes (granted it was on a Prelude but still OEM Honda) to test the ABS a few times ensuring its operational and activates (before i purchased it) and a couple of times (to avoid collision) later when i had purchased it and it didn't warp the rotors.
I don't expect good quality rotors to warp so easily. I'd consider the quality of the materials your life and car is relying on (if they have indeed warped on a single evasive manouvre).Last edited by JDMDriver; 08-31-2010, 10:57 AM.Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
Just check also that the calipers are not biniding.
I have experienced this vibration before on my brothers CD Accord and someone here also experienced it.
Turned out to be a binding brake piston (could also be another component on the caliper - slide pin?). Check brake wear of the pads that they are even (both inboard and outboard).
If the wear on the brake pads are not even, then chances are your rotors are not warped. The force the calipers (both left and right) are applying may not be constant and even.Last edited by JDMDriver; 08-31-2010, 11:20 AM.Rides:
Accord
CR-X
88-JDM-Si- Black
CR-X Del Sol
Prelude
Originally posted by JDMDriver View PostJust check also that the calipers are not biniding.
