I have a 1991 lx automatic. For various reasons the car was sitting for about a year. Once I started working on the car again I have ran into a few problems. First it would start but was in limp mode? The S light stays on constantly no flashing. It seems to only be in first gear in D3 and D4 and wont shit to 2nd or anything else. I can shift 1st to 2nd and 2nd works fine. After that I broke my ankle so the car sat again for a couple months. During that period I purchased a remanufactured tcu. After I was mobile again put it in and then the car wouldn't start. Replaced the main relay, and fuel pump so now it starts/runs like a champ, but still the same problem with the tcu. I attempted to get the diagnostic codes but no flashing from the D4.
Help!
Im not an expert but seeing you have replaced your TCU we can eliminate that from the equation (usually a common fix for tranny problem of this nature).
I think the other area of the problem coulb be your Shift Solenoid (cylindrical shaped component at the front of the transmission).
I read somewhere you can pull these out, clean them and check them electronically if they are operating properly. Use the seach button for "Shift Solenoid"Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
How did you pull the diagnostic codes? If you replaced the TCU and the light was still on, chances are the problem is with the transmission. Pulling the codes properly should tell you the problem. Another possibility is that your new TCU is faulty.
In the future, please make your thread titles descriptive. Everyone needs help, but nobody is going to be searching for "help" in the future. Descriptive thread titles help with future searches, and they also draw knowledgeable people to your thread.
AND, very soon, threads with titles like this will simply be deleted as they are found.
Good point deevergote sorry about that. I attempted to pull the codes but the s light is constantly on. Peronsally I think it is still the tcu. Only problem is if I open it up it voids the warranty. I am in the process of getting another one opening it up and making sure everything looks good internally, I will search the shift solenoid, but wouldn't that give me a code rather than just have the lit up constantly??
