Tranny Problem
    Tranny Problem
    I have a chance to get a h22 trans, the problem is that the JY where the trans is at,say's that the car dies when the clutch is engaged.
    The JY also said that the trans can be shifted through all the gears
    What could be the prob? Could it be an inernal issue
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    When my throwout bearing seized, my car would die when the clutch was pushed in. I don't believe any damage was done to the transmission itself.
      Niceto know, thats all it could be or is there an issue with the clutch from that car as well?
      NEW CB
      new
        I really can't make any sense of what you just said right there...
        If the throwout bearing failed, chances are all of the other stuff in that area is fried as well. When I dropped my tranny, my clutch was toasted, flywheel and pressure plate scored, pilot bearing was dropping balls everywhere...
          i think you mean throwout bearing balls were..since there is so pilot bearing only a bushing.
          worse comes worse you can tear a transmission down in about 45 minutes and truely see if you bought a junker.
