check engine light on the fwy
    for some reason or another my search feature dont work on my pc maybe its my computer.but anyway hi guys happy labor day. i have a problem i dont know how serious it is but im on the i405 hwy headed to the jy its half off day but anyway headed to the jy as i do every other weekend im half way there taking it easy cruising at 70mph an i throw a check engine light i pull over turn the car off checked over stuff all normal all guages normal except cel temp is where is should. so i jump back on the fwy to make it to the jy since im bout 10mins away so im back at it an no cel then the second i pull in to the jy the cel pops up i go in grab afew things head back home on the way home it didnt throw a cel til im like 10mins from my house what ever it is it has to get warm before the cel throws.so im off the fwy on city streets an i pull to a stop light an the car feel likes it wants the car wants to turn off. any help on what this could be would be great i wouldve just taken it to my mechanic but being its a holiday alot is closed.
    Usually, when that happens, it's an oxygen sensor issue. Not 100%, but often.
    Pull the CEL error code, and it will tell you what the problem is. If it's 43, that's most likely your o2 sensor.
    The CEL code will tell you what's wrong.
      Deev knows his stuff
      yeah deev is right usually its the o2 sensor problem but its not always the issue i know nothing of the CEL codes but im sure hes right
      What Do You Tell a Chick With 2 Black Eye's?
      Nothing You Already Told Her Twice
        http://www.youtube.com/watch?v=b6rEk9aXOmg hopefully this video will help u out bro
          I'm not even sure I'm right... he has to check the code before anything can even be close to certain (and even if the code says it's a bad o2 sensor, that still doesn't necessarily mean that's the entire problem)
            thanks deeve an everyone else for feedback but 92accordkidd with this plug your talking about do i have you unplug it or it should be hanging,also deeve it might just be the 02 because when i got the car the exhaust from the cat back was all rusted that would be a factor correct.
              hopefully its the 02sensor is it something i can diy or its a muffler shop deal,i got a legend lip an a spoiler for 23 bucks at the jy half price day ftw
                You just need a special socket. It's easy to do.
                  it should be in the kick panel under the glove box i believe correct me if im wrong but i never had the check engine light come on before so i dont kno
                    oh ok i think my ecu is under the carpet but do you know if all the connectors are the same color an wire configuration an color
                      your ecu is under the carpet on the passenger side if u look under the glove box u will see the 2 wires i believe
                        Did you see the "sticky" thread that said "PLEASE READ HERE FIRST"?
                        yeah... the information you need can be found in there. This is a VERY common question to be asked, so we made the answers very easy to find... so we don't have to tell everyone step by step 3-4 times a week how to do this!
                          ight thanks for the info anyway
                            i think i found another thread http://cb7tuner.com/vbb/showthread.php?t=21259 hope this one will help u more
                              thanks ALOT guys
