Spacers
    Spacers
    I found these for sale, but I think I would need longer studs eh?
    http://kitchener.kijiji.ca/c-cars-ve...dIdZ223392150#
    Can anyone confirm or deny this?
    5-10mm will be fine. but i and probably any others would suggest longer studs tho.
      I would go no more than 5mm for the spacer using the OEM studs and also make sure you're using the right type of lug nut as well. The integra type r wheels are ball seat as well as all other OEM wheels
        i wouldnt even run 5mm spacers with the stock lugs, i was with mike (greencb7inkc) when his lug nuts started to strip because there wasnt enough thread for them to bite fully onto and he's only running a 5mm spacer so his ITR's clear his brake calipers
          i was running 5mm spacers on my front studs. you'll be ok as long as you dont cross thread or tighten the lug nuts too much. you friend probably didnt know what he was doing. a lot of CB7 owners up here run 5mm spacers for their ITRs up here and havent had any problems.
            I too would not go more than 5mm spacers on stock studs.
            Also did you notice the center bore is different from our CB7. The CB7's center bore is 64.1. So you will have to get 2mm hubcentric rings to compensate for the difference. Which is pointless when you can just buy proper fitting 64.1 hubcentric spacers.
            Remember the point of a hubcentric spacer is to distribute the cars weight on to hub (very strong) and not directly onto the studs.
            Dont cheap out on something like this. Spend a few extra bucks and buy a quality product. Your playing with your life if this fails
            I run 25mm H&R hubcentric adapters with ARP studs
              yeah i think he was running 1/4" spacers which equates to about 7mm, and he may not have been using the correct Ballseat lugnuts.
