so i did some research on cams but im still a little confused on how to upgrade. i plan on going bisi. so i have to remove my camshaft (or get another camshaft) and send it to bisimoto so they can work on it? also i have to upgrade the springs depending on which upgrade rite? correct me if im wrong, this is just what i learned doing some quick research
camshaft upgrades
camshaft upgrades
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7MTags: None
Originally posted by buzz11 View Postso i did some research on cams but im still a little confused on how to upgrade. i plan on going bisi. so i have to remove my camshaft (or get another camshaft) and send it to bisimoto so they can work on it? also i have to upgrade the springs depending on which upgrade rite? correct me if im wrong, this is just what i learned doing some quick research
yeah the springs is a must even when you have the A1 cam and wanna swap to the more aggressive A6 camshaft your going to need the springs as well... imagine springs being run in your F22a1 for about 18 yrs the putting a bigger camshaft for performance those springs are going to take a beating being compressed alot....bisi has some springs too....oh and if you can send them your camshafti believe you can buy a core off them for about 100 bucks....seems fair to me!
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
if you get the stage 1, i've heard you can get by with your other stock internals, and also be able to run with the stock tune. if you go with stage 2 or higher, you need to upgrade your springs and get tuned.2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Originally posted by turboAccordHSF View Postyup..Bisi asks for you camshaft as an exchange or regrind by giving them your specs...Bisi is the number 1 recommended around herei'myet to find some punk say otherwise Bisimoto hasn't messed up in simple shit so when you buy parts from them expect quality work...
We also do have spring and retainer kits for both the Vtec and non Vtec models.
Originally posted by theSOB View Postif you get the stage 1, i've heard you can get by with your other stock internals, and also be able to run with the stock tune. if you go with stage 2 or higher, you need to upgrade your springs and get tuned.
The Bisimoto Stage 1 is literally a drop in and run camshaft. There is no need to upgrade anything else! The level 1 generally will give you 10% performance increase over factory! Bear in mind that if you tune with this cam your gains can be more.
The Bisimoto Stage 2 is a bit more of an aggressive setup. With this cam we suggest and recommend our Pro Spring & TI Retainer kit! Bearing this in mind a tune isn't completely necessary but again to take advantage of the performance abilities and potential of this camshaft a tune will help out to really extract every last bit out of it!
Originally posted by winston101 View PostIts best to upgrade the springs, its not a must for stage one. but if your going to change the cams just redo the head port and polish, springs and get a stage 2 or 3 cam. do it once do it right. nothing worst than have to buy cams 2 different time for the same car.
In either event my suggestion is to get springs and retainers at the time of your cam purchase. Even if you stick with a level 1 it is nice to know that you have the security of 14000rpm before you can start to worry!
Shoot me an email if you need anything or if there is anything else I may assist with!
Randy@Bisimoto.com
Originally posted by bcjammerx View Postdo not forget the teflon spacers...though I can not find them on the site
http://www.bisimoto.com/sport-compac...-extended-pads
for level 3+2013 Ice Cream Cruise!
By 1320 Video
Cheers
-randy
Its debatable, to be honest in my opinion our Bisimoto Level 2 isnt aggressive enough to require it. Our Bisimoto Level 3 and X cams are race cams so with that in mind those would need the spacers due to the aggressive nature of the cams.
Weekend warrior setups generally are fine but anything that will constantly and repetitively see track time will need the spacers as well as extended rockers! Bearing this in mind, we recommend our valve train in both situations due to our assurance and testing. Our springs and retainers are spun test to 14,000 rpm to ensure that they will not fail on you our client!
Should you guys have any questions, comments, or concerns feel free to shoot me an email!
Randy@Bisimoto.com
So the spacers are just more durable and don't actually provide any power upgrade, I would assume.
What is the difference between the stock rockers and the extended rockers? I know the race rockers are lighter, I'm assuming extended has a better rocker ratio? They must be somehow stronger too?
Originally posted by Sarthos View PostSo the spacers are just more durable and don't actually provide any power upgrade, I would assume.
