I have a 92 Accord EX coup. I am ready to do some serious engine upgrades, but I am wondering if I should purchase a newer engine. I have over 200,000 on the one in my car, but it runs great, doesn't burn any oil but does have a slow oil leak somewhere. I can buy a refurbished engine for $800. I could buy an engine stand or mount, whatever they are called, and do all my upgrades to that engine and drive with the engine I currently have while I build the new one, then just swap engines when I'm done. It seems to make sense to me, because I could then take my time building my new engine instead of being without wheels every time I have to take 2 or 3 days upgrading my present engine. I don't want to buy an H22 because the f22 can deal with a turbo much better. I think it's a good idea, what about you guys? Thanks, Fly.
should I buy a new engine?
Why do people constantly insist that the F22 is "better" for turbo? I see this like, 3 times a week... where are you people getting this misinformation?
Anyway, yes... buying a second engine to build is smart. However, I wouldn't spend $800 on a refurbished one. I'd suggest spending $50 on one that needs work, and build it to suit your needs. A stock rebuild for $800 is still going to blow the ringlands one you boost it.
Originally posted by fly68 View PostI have a 92 Accord EX coup. I am ready to do some serious engine upgrades, but I am wondering if I should purchase a newer engine. I have over 200,000 on the one in my car, but it runs great, doesn't burn any oil but does have a slow oil leak somewhere. I can buy a refurbished engine for $800. I could buy an engine stand or mount, whatever they are called, and do all my upgrades to that engine and drive with the engine I currently have while I build the new one, then just swap engines when I'm done. It seems to make sense to me, because I could then take my time building my new engine instead of being without wheels every time I have to take 2 or 3 days upgrading my present engine. I don't want to buy an H22 because the f22 can deal with a turbo much better. I think it's a good idea, what about you guys? Thanks, Fly.
Buy another cheap f22 that needs work or something, if your going for boost, you'll need some good engine management! Cast pistons won't hold long, if your doing a serious build fork out the extra money and build it right, I boosted my stock f22 with just injectors fpr and a p06 with an f22 basemap 10psi, cracked 3 pistons and shattered the last and blew my headgasket the same day I got it all hooked up...lol
Originally posted by winston101 View PostBoth enginge are good for boost, the h22 is just a more work and more money. I would buy a second engine for cheap, use that 800 for new piston and rods. this way you will be able to drive your car will building the motor correctly with out having to rush.
Originally posted by deevergote View PostNeither engine is good for boost in stock form. The stock ringlands will always give out.
Just an fyi, The stock F22 can handle boost better than the stock H22 due to FRM on the h22. The F22 cast iron is more efficient than the FRM.
But since you want to rebuild that's kinda irrelevant.Last edited by Reignstarz; 09-28-2010, 10:51 AM.
Originally posted by winston101 View PostNO a stock f22 in good shape can take normal amount boost 5-8 pounds. But thats why i said to get another f22 and use that 800 to buy better piston and rods.
Yes, if you replace the internals and tune properly, low boost will last a long time, as long as nothing unexpected happens (wastegate failure, fuel failure, etc... plenty of potential problems!)
Forged pistons that are designed for turbo expand and contract a bit, unlike NA pistons, which are very rigid (and therefore brittle, and not right for boost). Pistons designed for turbo motors will usually slap until the engine is warmed up. This can beat the hell out of the cylinder walls, and eventually compromise the integrity of the engine.
Originally posted by deevergote View Posta stock F22A in good shape will take 5-8lbs, sure... until the ringlands go. And they will.
Not being a smart ass, just an honest to goodness question by someone with very little (and probably misinformed) knowledge of turbocharging deev! =)
A turbo engine will wear faster. That's just how it is. Stronger sleeves will withstand piston slap better than worn stock ones.
Also, advances in technology may have produced stronger alloys that don't fluctuate in size as much. Since I'm really not a turbo expert, my information may be dated. In fact, my sources are at least 10 years old, I'm sure.
However, that's how I know things to be... if anything, it's something to research and either prove or disprove based on today's available parts.
