I have a 92 accord 2dr 320k miles automatic very clean! bought for 250bucks using for a winter car, basically what happens is every once in a while I turn the igniton to the on position and my gas gauge falls all the way to e. Try to star it it won't start unless you pump the gas. But pumping the gas seldom works, otherwise I let it sit for like half hr then it fires right up, good spark, the fuel pump won't kick on when the gas gauge drops... any ideas? Iacv? I already resoldered the main relay under the dash and drilled holes in the casing so it breathes...when it runs it runs great! Good power and everything. I'm just stumped on why it don't start sometimes..
92 accord wont start sometimes?
fuel pump ?-----------------------------------------------
''It is what it is, Do what you want''
http://www.cb7tuner.com/vbb/showthread.php?t=167905
main relay, pumping the gas pedal on a fuel injected vehicle wont help infact it will most likely flood, but I would deff check the solders on the main relay since it wont cost anything to diagnose and its a common thing on cb7s
EDIT: sorry I just read the whole resolder part of ur post but it still sounds like the relay, the iacv wont prevent the car from startingLast edited by 904drACCORDMANG; 09-28-2010, 08:56 PM.
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
could be a faulty ignition switch
