does this trans fit this engine???
    does the single cam accord trans bolt up to an h22?? cuz i plan on an auto to manual conversion and i heard that h22 trans arent that great and that the single cam accord trans can bolt up to the h22 and is a much better trans... does it bolt up and if i put the accord manual trans mount on the auto accord bracket will my engine be tilted or do i have to weld a new bracket on ??
    All f and h series transmissions are interchangeable with other f and h series motors. The f22 transmission has longer gears, whereas the h22 and h23 have shorter gears. The h23 transmission has longer gears than the h22, but shorter than the f22. Hope that helps.
      yes it does, the f22 box has longer gears, that dont make it any bettet really...i think the h tranny is the best but its your choice...
      MRT:http://www.cb7tuner.com/vbb/showthread.php?t=164408
      And on the eight day God created Honda!
        cuz wen i had mt 97 accord i luvd the feel of the trans nice didnt rev high at all wen cruising but i never drove a vehicle with an h22 trans so idk wat one i would get i dont wanna get the h22 trans and be dissapointed with the feel
          now lets say i was to get an h trans could i take the f22 fifth and put it in the h trans so it will be at lower rpms wen cruising???
            F/H Series Transaxle Info (Manual & Automatic)
            http://www.cb7tuner.com/vbb/showthread.php?t=37839
              i seen this earlier but it doesnt answer my question if the f22 5th will fit in a h22 trans
                ^^^ You Kno What I Dont See Why Not, If A F22a Trans Can Fit A H Block, And A 5th Gen Trans FITS A F22a Block, Then I Would Think Yes.
                I Dont Kno If You No This Already, But In Order From Longest To Shortest Is
                F22a
                F22b1
                H23
                H22
                I Kno A Guy From Nj, Name Is Brian, He Had A Sedan Cb, With A F22b1 Trans, And He Said He Can Pull On Any Stock Accord With F22a Trans Which I Can Beleive Cuz The F22b1's Tranny Is Slighty Shorter Than A F22a.
                  F22a
                  F22b1
                  H23
                  H22
                  sorry let me rephrase it can the 5th gear from an f22 trans be put into an h22 trans ...like i have tsx 6th in my rsx trans so wen i jus cruise i cruise at low rpms and save more gas get me now??
