last H22a ?s plz help
    ok guys im down to my last few ? for you
    1. Vacuum line #8 that runs out of a little black box on the front right side of the car is really long, well i have all of the vacuum lines out of the black bock running somewhere and i have no where that i know of to run #8. can i just close it off or does someone know where i can run it?
    1. I have figured this one out already after I put the air intake on I found a plug at the bass where I just ran it to.
    2. I have a coil pack pluged in but no coil wire running to the distrubutor my car still started though so do i need to have a coil pack? or its it inturnal? its a OBD-1 JDM H22A.
    2. From what i have been told the JDM H22A does have an inturnal coil.
    3. I have one wires left to plug in both are on the right side of the car by the distrubutor. Its a green plug and after that im pritty sure that i have all of the pluged in.
    4. Now my last ? is there is a black cylinder next to the T. body and the V-tec solenoid it has the same kind of plug out as the map sensor but i used the F22A6 wiring harness so i only had one plug like that.. so do i need to run wires to this or just forget about it and what is it anyways?
    4. ok i found out that this is the exhaust gas recirculatoin (EGR) valve the two plugs are different then the F22A6 and the H22A. On the F22A6 its a squre and on the H22A its more of an ovel so i just cut and swaped the plugs.
    here is a video showing what im asking above...
    http://www.youtube.com/watch?v=vrSlBmOfoLE
