h22 oil burns
    h22 oil burns
    Do all h22 motor burns oil just wanted to know
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
    mine does not burn a drop.even after 6k miles still doesnt smell burnt or anything like that.i use RP oil
      Mine does, was using Mobil 1 and was loosing quite a bit. I switched over to castrol syn. Been fine so far, not too much. If anything use a heavier weight.
        Most burn oil, yes. Just the nature of the beast.
        1994 Honda Accord SiR Sports Sedan
        “When I do good, I feel good; when I do bad, I feel bad, and that is my religion.” - Abraham Lincoln
        CD5Tuner - A Fifth Generation Accord Community
        PS3 tag: Mechtroop
          The one that the previous owner swapped into my car and rebuilt himself ended up burning about a quart every 200 miles before i swapped in a fresh motor. The one I swapped in burns zero oil. Well, all engines burn some negligible amount of oil. Some H22s burn more than others, some burn nearly none, some burn a quart between oil changes and run fine otherwise.
            Yup mine burns about a half a quart every 1500miles .. Royal purple
            Originally posted by wed3k
            i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
              I use Castrol High Mileage 20w-50. Don't burn any. Stays the same since my last oil change. Reminds me too. that I should do one soon, been about over 6,000 miles. eek!
              new $10 purple/yellow tint fog lights
              H22a Sleeper:
              http://www.cb7tuner.com/vbb/showthread.php?t=124470
                Damn FRM cylinder walls
                www.PreludePower.com
                BB SQUAD MEMBER #28 V.2
                  i think i might just have to use a diff oil like 10w-30 beacuse i use 5w-30 now that what the h22 run on is it true or not
                  91 cb9 wagon
                    Most Honda engines are recommended 5w30, which is a good weight for climates where its neither too hot, or too cold. With the Texas heat, Id recommend 10w30. Its what I use, I still burn a bit of oil, but its nothing to go crazy about.
                    '09 Mini Cooper S (R56)♥
