cleaning out fuel injectors
    jus found out my car had no airfilter since i bought it,, thought it was there the whole 50k miles i had it. wondering what to clean out my whole fuel injection system and engine out with, because i wouldn't doubt that its dirty,, i need help bringing my baby back to life.
    Just buy some Fuel System Cleaner from an Auto-Parts Store (I use the Gumout Brand). Pour into nearly empty gas tank then fill the tank with gas and drive. You should feel a noticeable difference. Hope this helps.
      Running without an air filter won't do much to your fuel system and injectors.
      The dirt went into the engine itself. Fine gritty particles mixing in with your oil, acting like sandpaper inside your engine... tearing up your cylinder walls, bearings, etc...
      Run some Seafoam in your gas tank and in your crankcase (according to the instructions on the bottle.) Then change your oil. TWICE. That will clean the engine as much as possible. If any damage has been done by running for 50k with no filter, it's not going to be repaired by something in a bottle.
        shoots,, sounds good, better than nothing.
