DOES ANY ONE KNOWS HOW TO REMOVE THE BACK SEAT OF A 92 LX 4 DOOR?? BOTTOM ONE THANKS
back seat removal???
This topic is closed.
Use your key to fold the seat down, two bolts, one on each hinge, i believe 14mm. The carpet will need to be unhooked from the trunk prior to this. then one bolt in the middle on a small metal tab for the bottom portion. Lift up from the back and pull up to unhook it. It literally takes less then 5 mins.
