91 EX - Won't Start...
    Here's the vital stats:
    - All accessories work, headlights work, radio, etc. work.
    - I turn the ignition and the car turns over.
    - The starter sounds strong with no lag.
    - Battery is one year old - seems strong.
    - Recent new alternator.
    - Engine replaced one year ago with rebuilt engine (had ~ 35,000 miles on it, now has maybe 50,000 miles).
    - Fluids all look good.
    - Full tank of gas.
    - No blown fuses.
    - All connections, wires, etc. under hood look good and intact.
    My car was running fine up until yesterday morning. Then suddenly it wouldn't start. I vaguely recall that the day or two prior to this, the engine was a little slower to start, but I don't remember it being significant or anything to worry about. And I've driven used cars forever, so I tune into those sorts of things.
    One other note. The day before this happened, I wired a flashing LED - positive end into the hazard switch and negative end into the cruise control fuse in the drivers side kick panel fuse box. I did this to act like a fake alarm - wiring it like this so that it would turn on only when the car was off. Just after hooking this up, I started and drove the car - no problem. The next day I did not drive the car and the blinking light flashed all day and that night. A blinking 3v light, though, shouldn't drain the battery, and the battery isn't even the issue as I explained above. I have since disconnected this LED and, as I said, all accessories work fine. I'm not sure this has anything to do with the car not starting. Maybe it's just a coincidence.
    Please help! Any advice appreciated!
    91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
    Neuspeed Super Cup Kit (7/2010)
    TAS rear drum-to-disc conversion (6/2010)
    Above photo taken - 4/2010
    did you check for fuel or for spark?
    also listen for your fuel pump to whirl when you first turn the key to on position
      I'm not sure how to check for spark by myself. I don't have a spotter at the moment. As spark is what I think it might be, I'm thinking of just changing the plugs, though. Even though they are only about 1 year old.
      And when you say, "check for fuel" do you mean to listen for the sound of the fuel pump when I first turn the key on? I'll check this.
      Thanks!
