Idle Jumps
    Idle Jumps
    So when I started the car this morning, I noticed the RPMS jumped to 2500 or so, then back to 1000, then back to 2500...weird...when it gets warmer its fine. I'm thinking Idle Sensor?
    1992 Honda Accord EX (Rosewood) - RIP
    I THINK THAT IS NORMAL ON CB7 CUZ MY DOES THAT TOO ONLY WHEN ITS COLD BUT IDK MAN
      That could be a few things, but there are diy's on the forum for both cleaning your IACV, Screwing down your FITV, and properly setting your base idle. Those should all help remedy the problem, but there could also e a vacuum leak somewhere.
      OR SOMETHING LIKE THAT IDK MAN!?>!>?
        i think that if the base idle is too high it will start to do that
        what does your car idle at when its warm?
        also try pulling the ecu fuse to reset it
          i just cleaned by iacv because mine was doing the same thing. now it doesnt. soooo much carbon build up. try that. its a $4 fix.
            Mine is doing the exact same thing, it only happens when the engine is cold. Once it warms up, it goes away. Gonna try cleaning the iacv like agol did.
