Ok , so i was driving home from school ( about 15 miles) and right before i pulled into my driveway my car started to rev very oddly. it would bounce up and down and i limped my way into my driveway. can any 1 tell me whats wrong?
H22 rough idle
Revs up and down, up and down constantly?
Sounds like either the IAC Valve (Idle air control) or the idle air screw backed out. The idle air screw is on the throttle body near the vacuum ports, it's usually a large flat headed screw, just put your finger over the head/hole to see if the revving goes away. Basically that is just covering up the vacuum leak if it backed out too far. If not that search for cleaning method of the IAC valve.
Robert
check your coolant level first and see if its low. You could have air in the system.
Next, if thats ok, then take a screw driver and hit the IAC valve when the car is on and note if the idle changes...if it does, then its probably that IAC valve thats going bad. But you can try and clean it first if that does anything, take some Carb cleaner and spray the shit outta it until the runoff is clear.
