idling problem, helppp pls
    my car started reving up 2500rpms n down to bout 1500.. and it does everytime i come to a stop.. i was told to clean the IVAC and so i did. now its surging at bout 500,600 rpms n feels like it wants to stall n it does end up stalling.. so everytime time i stop it comes down to bout 100rpms n comes up to 500,600
    so how exactly did you clean your IAC (Idle Air control) valve?
    90 accord lx
    form > function
    Member's Ride Thread
      carb cleaner O_o
        i had the same problem. Do you happen to have a aftermarket cold air intake on your car? if so you may have to change the sensor because its possible that you can have too much air going in and cause it to idle oddly.
          I've had my Idle control valve rebult twice...carb cleaner is one method but you really should use something less 'dry' for the o-rings...but yes irregular idle is a direct relationship between the ICV and the timing...
            yea i have an intake... and idk it might be timinggg : /
              I cleaned out my icv and it doesn't rev as wildly but tstill does it!!!
              So i feel your pain homie!!!
              can you really take it apart and rebuild it?
              how?
              I AM KOONCE THE LEGEND!!!
                Notice the screws that hold the sections of the IACV together are not made for any screwdriver most of us have in our boxes. If you do manage to take the valve apart; as far as I know, there are no replacement gaskets available to go between the top and bottom. If you compromise that gasket to where it no longer has a tight seal then it's bye bye IACV and hello ebay, Honda parts counter or JY unless you get really creative and manage to make a new gasket for it.
                Be sure to bleed any air out of your cooling system after cleaning IACV. Slim possibility air got let in while you had the hoses off the IACV or FITV. Also, I don't recommend tightening down the ring on the FITV till it won't tighten any more. Try loosening it in half turns and see if that helps your idle. I personally think the FITV gets messed with way too much.
                  thanx homie!!!
                    hey i know this was pstd a while ago, but when i took off my iacv i used some rtv silicone and it sealed it right up. only downside is u have to wait a few hours. but it is still holding today!
