Coolant disapearing from resivor
    Hey so i was filling up gas and i went to check my coolant overflow resivor and it was really low. i walked in to the gas station and bought 50/50 antifreeze and put it in. i drove home and it seemed as i had a coolant leak. i noticed that my coolant is slowly going down. once it goes down it seems to stay at the same low level that it was when i first caught it. Can anyone tell me whats going on. i checked the color of my engine oil and coolant and it was normal btw so i dont think its time for a new head gasket.
    leak in the radiator, radiator hose's, water pump gasket?
    hoses going to your intake,heater
    could be alot of things coolant goes lots of places
    ''It is what it is, Do what you want''
    http://www.cb7tuner.com/vbb/showthread.php?t=167905
      Is the radiator full?
        you cannot go off the overflow tank. You may have a crack or hole in it.
        When your car heats up the anti-freeze expands, bubbles, etc...and goes into the tank...as the car cools etc etc...it sucks it back out. So if you have a crack in that tank it can lower your anti-freeze levels.
        Check it for cracks, check your hoses for leaks, check the rad for leaks. Then, fill the rad all the way up, squeezing your hoses to get out air. Then fill the res. tank. Close the rad and continue to squeeze the hoses...you should get some bubbles go into the res. tank, then when you release the hose it'll suck in anti-freeze.
        Run the car with the heater on (make sure the knob is turned to hot so you get bubbles outta the heater coil)
        TAKE CAUTION HERE...hot engine and anti-freeze:
        Then on the firewall side of the head on your left (when facing the car) there is a bleeder screw on the water outlet, unscrew it, this it the highest point in the cooling system. Squeeze the hoses until you get only water out.
        But...all of that will be in vain if you have a cracked res. tank, rad, or hoses...so again...check those first.
        ____
          ok so i just added more anti freeze into it and since then it was fine and i didnt see any coolant leaks. im thinking i could of have pockets of air in my system?
            im haveing the same problem does anybody know where i can find a diagram of the radiator and pipeing can i can only see the 2 big hoses but when i checked there werent any leaks coming from them?
              http://www.hondaautomotiveparts.com/...catdisplay.jsp
              ''COUPE''
              ''WAGON''
