ok so with my h22a swap im blowing out my motor mounts like crazy already replaced 2....with a blown motor mount can u just put the polyurethane inserts in them and make them basically new again or how does this work? what other motor mounts fit in cb7's? does the cd6 mounts fit?
motor mounts!!!
I've never liked the windo weld option, but it works for some. I forget the name of the stiffest urethane possible to use... it's mentioned on this site somewhere.
Anyway, inserts will NOT fix a broken mount (it even says so on the packaging.) You have to replace the mounts, or fill them. Replacing is better, honestly. Check out ESP for performance mount upgrades (www.explicitspeedperformance.net ... they also have a Member Shop on this site, and are running a sale through today!)
If you're blowing out your mounts like crazy with your H23 swap, is it possible that you did something wrong?
I've always taken even perfectly good mounts, cut basically all the rubber out of them, leaving just enough to hold the inner sleeve correctly. Then I'd fill them w/ McMaster Carr urethane. The more rubber you take out, the more room for ureathane, plus, the ureathane is "keyed" which it will never come out and it's more surface area for added hold.
This is of course if you have the downtime or an extra set of mounts. I also do not like window weld, not even close to being hard enough.
[QUOTE=deevergote;2668974]I've never liked the windo weld option, but it works for some. I forget the name of the stiffest urethane possible to use... it's mentioned on this site somewhere.QUOTE]
contruction adhesive, PL in a yellow tube. Thats the hardest.
I to used window weld in my van for the motor mounts, just make sure its dry.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
