So my cb7 is having afew issues with the transmission. Today when i stopped at a stop sign the D4 light on the dash went out and the car wouldnt move more then 3mph if that. So i placed it into park and shut the car off and then turned it back on and the car was stuck in park so i placed my extra key in the shift slot hole and placed it into D4 and it still did nothing. So i placed it into 1st gear and it moved but once i placed it into 2nd it did nothing but once i placed it into D3 it shifted right into it fine. But everytime i would go to a stop i would have to put it back into 1st gear or i wouldnt be able to move at all. Once i got home i put it into reverse the reverse and D4 light would be on till i moved. I have looked up this issue but cant find a final issue...So im thinking its either tcu,trans cable or the shift solenoid.
This is my daily driver and need it fixed asap. Thank you very much and this is a 92 LX btw
