Hey guys, i'm thinking on changing my cv joints, and i found some but the guy isn't sure if they fit my accord, they fit 91 prelude and are 30x28, in the teetg ccount, and i don't have my joints out to count, so can anyone help me?
CV Joint
Originally posted by TypeG View Postthat's a lot of work just to find out they don't work. why not just put what you know will fit? later.ok, thanksOriginally posted by deevergote View PostThere are no axles from any other cars that will work on a CB7. Use an axle made for your car.
i wuz askin cuz the guy had din the advice, cv joint for 90-94 accord 90-91 lude
but well.. keep searching then
Greetings!
"din the advice"?
The 90-91 Prelude has completely different dimensions, and uses an engine and transmission that are completely different from the 90-93 Accord's. Axle length will not be correct, even if everything else is.
Even the axles from a 92-96 Prelude, or 94-97 Accord will not work... and both of those cars are MUCH more closely related to the 90-93 than the 3rd gen Prelude is.
ahh i see.. anyway, i'm looking not for the axle, (if that i s the arm coming from the tranny, i'm lookin for the tip that has ball bearings on the wheel, dunno if u get me :SOriginally posted by deevergote View Post"din the advice"?
Ah, ok. I see what you mean.
It MAY work, but I wouldn't bother. Assembling your own axles often results in an unreliable result anyway. Do you have access to any stores that sell remanufactured Accord axles? In the US, they are quite easy to find, and very affordable. I just checked your IP address and I see you're from Chile... so that may change things a bit.
yeah i have to travel 400 km to buy that stuff, cuz i hav to search for the cheapest parts, japanese built, hahaOriginally posted by deevergote View PostAh, ok. I see what you mean.
It makes sense now, I was just about to tell him that Autozone has them for 39.99 a piece.Originally posted by deevergote View PostAh, ok. I see what you mean.
CiRcuS kiNgZ
Because he's in Chile, and it's a 400km trip to the nearest store that sells them. If you bothered reading the entire thread before you replied, you'd have known that.Originally posted by Drifting in 808 View Postim going to have to change my axle also. i put it on a lift and i seen how torn up it was and it was destroyed. going to napa to buy a new axle for 60 bucks. why dont you just buy a remanufactured axle.
Great. Now do you want to help the OP out by showing him the nearest O'Reilly Auto Parts in Chile?Originally posted by KoonceSSDAccord View PostI go to oreilly auto parts!!! lifetime warranty as long as you own the car!!!
you just gotta buy the 1st one!!!
and it truly is warranty i'v had to cash in on this sevreal times with both sides!!!
Or did you just not bother reading the thread before you posted?
