so i have a problem to start my car when ever is a little cold out there it takes like 4 times to turn on nd when it does it shakes a lot nd it just shuts down again even if i step on the gas so i have to started again like 2 times so it finally it starts but the RPM it like at 3 nd when it warms up the RPM is below 1 well this the problem with my car can any of u guys help me?? thank you very much
problems when staring the car when cold
i just bought the battery a week ago the oil is valvoline high millege the motor is a f22a1 automatic and cold is beloW 40Originally posted by DariuszZ View PostHow old is the battery? What kind of engine oil are you using? What motor, you need to provide us with some kind of information. What do you mean by cold? 0, -10, -50?
what kind of the oil? 10W 5W 0? Plug the car over the night so that the oil doesn't freeze, also you could add some anti-gas freezer into your tank next time you fill up. When the engine is cold, it will hit 3k for couple of minutes and once it warms up it will get below 1k, so that's perfectly normal. -40 man, what did you expect??
