knock sesor ?s
    knock sesor ?s
    i was woundering if thers other knock sensos that will fit h22a
    Cross-reference Honda part numbers. If the part number is the same for other engines, the part is the same. If it is different, then I woulnd't expect it to work... but you could always give it a try. If it doesn't work, it'll throw a code. The knock sensor is basically just a microphone. If it doesn't work, it won't damage anything. Chances are, if it doesn't work, it won't even plug in.
      I have a knock sensor from a 6th gen Accord on my h22, works fine.
        thanx guyss
