electrical/motor problem...
    hey guys...
    yea for some reason my tail lights dont turn off wen i shut the car off... idk wats the problem...
    also 30 seconds after starting the car the motor like revs itself without pushing the pedal..idk why...
    search.
    FICV-fast idle control valve.
    Is your tail lights on, brake lgihts, or parking lights?
    brake lights-check brake switch or brake stopper above the brake pedal
    parking lights-bend over
    Retro!
    Hater
      yeah its the fast idle...
      its the brake lights bro..so i should check the swith then..
        check the switch, but at the switch you SHOULD see a thing that the switch hits to turn on and off. Sometimes that breaks off and it will make the lights stay on.
        Retro!
        Hater
          it was the that little blocker that broke off...but i fixed it..
          its not the fast idle i think its the air valve
            clean the iacv and set base idle with the iacv disconnected after cleaning.
              haha could u break it down wat u said a little easier man lol
                first clean the iacv (idle air control valve). then set ur base idle. (theirs a sticky in the diy section). then plug the iacv back in. also my car revved up and down from the tps being out of specs
