fuel gage problem
    fuel gage problem
    So this is not a cb related problem but i really could use your help. My friend has a 89 240sx he is boosting so i changed the fuel pump to a walbrol. So i put the sending unit back and the gas gage wont work i checked the float and its ok checked for any damaged wires nothing. Any help that can be provide will be appreciated. Its his dd and it would be nice if i can figure this out.
    STANCE|WORKS
    thats simple...does the cluster come out easily?
    id unplug the harness from the back of the cluster and find the pin out for the sending unit. check if resistance changes while you move the float. im thinking connection issue or sending unit.
      Thanks i will be sure to give it a try tomorrow and see what will happen.
      STANCE|WORKS
