axle replacement
    axle replacement
    hi all! i need help with the drivers side axle replacement. i just recently moved and my hanes manual is baried in my storage unit. can some one give me a detailed instruction how to change the axle. i have an 91 lx with an automatic trans. thank you in advance!
    http://www.cb7tuner.com/vbb/showthre...highlight=axle
      thanks!
        if you read down threw that you will notice that she popped the lower ball joint out. you do NOT need to do this. you have a good chance of ruining your ball joints if your not careful using the fork. if you have the patience you can remove the 2 nuts (17mm) that are on your strut towers in the engine bay. you will then be able to pull the entire arm down which in my opinion is much easier. takes a little more patience as you have to fight the axle a little more to get it out of the hub but it is possible. if you need any pics let me know and ill see what i can find for you.
          since all that holds the ball joint in is pressure it would be wise to replace the ball joint when you do the axle.
            unless the ball joint is worn it shouldnt need replaced. i just did the ROH conversion (everything got replaced. bushing ball joints hubs ect.) and a month later the trans when out. no need to replace the ball joint.
