Oil Leaking PLEASE HELP
    1991 HONDA ACCORD SE
    my cb7 is leaking oil but is not from the oil filter is next to the oil filter then when it gets warm all the oil goes to the exahuast then smells like burn and smoke. Any ideas on how to fix this??????????
    It could be the oil Pressure sensor, its right above the oil filter. I had it happen to me once. You can either replace it or plug it. I plugged it, but I check my oil more often because I don't have that sensor anymore.
    Its tough to get at (even tougher to take a picture of it!) But its doable.
    Good luck!
      OK ill try, but would the oil pressure sensor will make the oil stop leaking?
        Check to see if there is oil above your cooler, if so then its the OPS. If not then its the cooler gasket, just replaced mine this weekend, $5 at from the Honda dealer since the local auto parts stores didn't carry it.
          My daughter's 93 lx was doing this and it was the oil pressure sensor. You can get one from Advance or Oreily's. Takes about 5 minutes to replace.
          http://www.cb7tuner.com/vbb/showthread.php?t=178069
            Put the car up, clean everything in that area with brake cleaner, then run the engine. It could be several things. 1-oil fliter leaking, 2- oil fliter housing seal, or 3-oil pressure sensor.
              X2
              Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
