check your fan timer under the dash, on the driver side
Cooling fans not working at all.
Originally posted by James Matteu View PostUnplug the one I have highlighted RED in the photos I posted above, stick the paperclip in side with wires coming out.
'Drifting in 808', my bad, I don't mean to confuse you. The one I want you to jump is behind the distributor and looks like the one I circled in YELLOW. I don't have a pic of the one behind your distributor, and it is not pictured in the photos I posted.
You're right, the one you replaced for your gauge cluster is the BLUE one. The RED one tells your ECU what the coolant temp is.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Engine Coolant Temperature Switch A1997 Honda Accord EX-V6:
I'm confused here. I think you answered your own question though. If it needs to be grounded to work, then it's not grounded Electrical components need a complete circuit to work, sir. Think of it as a circle or continuous loop of flow from power to ground. No ground = no loop = no fan. And know that most insurance companies don't cover fire damage from improper wiring.
